Price of installation of Cams
Gang, I'm looking to compare the price that I was given for the installation of Wood's 222, pushrods and a tune. My local shop said $2K which I think is really high. The install is on a 2012 SG and I already have a dynojet.
Please, I'm not looking to compare cams, rather what you personally paid to have a shop do the install.
Thanks!
Thanks!
I just did 24d cams w bearings $210 , SE adj push rods w/tubes $150 , Fueling tensioners $20, Johnson Hylift lifters SE $120, rocker lockers $15, new cam bolts $5, complete gasket kit $95, new exhaust gaskets $10, misc. shop supplies (oil, filter, assembly lube, o rings, loctite, etc) $75, new Power Vision $400 = $1100 total in parts and supplies. Without the PV it would have been $700 in parts and supplies.
***Note to anyone doing cams its best to upgrade your stock lifters at the same time.***
Labor done in my garage with help from a friend who had all the specialty tools to change bearings, check crank run out, etc. I did the tear down and rebuild he did the the cam chest work.
Bike runs awesome! Plus I have the satisfaction of knowing it was done right and no corners were cut or expenses spared (just shopped hard for all parts in advance).
I had so much fun the next week I tackled new tires (Metzler 888's) and brake pads all around (Lyndall Z Plus). Like having a new bike with all the upgrades.
Did mine myself, for the cost of an ebay cam bearing tool. Paid for itself and then some. Now can do mine and friends bikes later if need be. Its not hard. You'd need bolt cutters too for pushrods, unless you take rockerboxes off. Get a Powervision, tune it up. Dynotune would be nice later, but not needed to get you in the good enough range. Hundreds left over for fuel
Yeah it's been a little bit for sure. I'm telling you man consider the install. It's really pretty easy...have I ever steered you wrong? Don't say audio either!
One of my riding buddies recently bought a 2013 Road glide from a metric shop. It definitely has cams because it peels off like a beast. A group of friends did a long ride and he was ripping up the roads/highways. It was all low end torgue. Based on that, I'm assuming that he's running 222's. I can't think of any other cams which gives that much power on the low end.
I remember when you installed your 222's. Any issues or regrets? I was thinking about 555's but I think for the 2000 - 4500 rpm range which is where I live, 222's is perfect.
