09 FLHP needs rings...what else should I do with the hood up...
what is the cost of just doing rings? I would want to match cylinders to piston for optimum compression. are you getting blue smoke when running or at initial start up? I would talk to dyno steve and see what he recommends. since he has worked on it before. Provided you were satisfied with said work.
Just reading this, if you were burning oil past your rings you would have blue tinted exhaust leaving the mufflers, was that happening when you rode? When the bike was at operating temp?
I'm curious what your Indy's say, since this is starting from chasing an oil leak/1-2 qt every 5K. Were your breather tubes re routed or are they still going into the throttle body? How does the air cleaner and throttle body look? Any excessive oil?
I don't know how the breather tubes are routed however there is typically few drips of oil after a service. All of the info was relayed to me by their scheduler which is why I didn't have any work beyond the test run, I asked if they could do the port/polish on the heads if I did do the work and they farm that out. That work goes to Cyclpath who is the other indy I have worked with. I'll be calling both Cyclpath and Dyno Steve for input.
THx all for your insight on this!
Ride safe.
The dealer has admitted his lack of knowlwdge already in the results he gave you.
Your engine is being condemned by someone that does not know how to do a leak dwn teste or does not own the tool to do it??
There are so many reasons you can get a low crank number with a rollover CR test, I can't list them all.
Tell him you want a leak dwn by someone that KNOWS how to do it!
Kingglide549 (01-19-2019)
Campy Roadie (01-19-2019)
Hi All,
My 09 FLHP with ~67k miles is at the dealer and I got a voicemail that after a compression leak down test, they are recommending new piston rings. I am not an expert here but if the pistons and cylinders are still OK, what else should I look into while the heads are off. If I were ever to get the heads ported/polished, wouldn't now be the time? Anything else?
THx
THx
If you're going that far at least have the valves and seats resurfaced, no need to port and polish etc unless you just have to throw money at it or are unhappy with the current performance.
Might want to check your air filter too. Some of the free flow air filters will allow debris into the motor which in turn will prematurely wear the cylinders.
