Ohlins With Lowering Blocks
Old 03-18-2019, 08:27 AM
62hdbiker's Avatar
62hdbiker
62hdbiker is offline
Default Shocks
I have been using the LAC lowering blocks on my 2011 ultra. They don’t change the geometry. O am using the 13” olins
Old 03-18-2019, 11:17 AM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 47,998 Likes on 17,504 Posts
Originally Posted by Softy 103
How do you feel about the ones that do not swing the shock back but straight down
Haven't seen those. Keeping the OEM geometry is good , I'd be looking at the way they mount to see if anything is stressed by going out board.
Old 03-18-2019, 09:03 PM
klammer76's Avatar
klammer76
klammer76 is offline
Please note in the last 3 picture the lowering blocks and this is just one of dozens of threads that been been posted in here alone, Isn't a myth bud, been dealing with those things since the Evo days when short chubby guys had to get their biker freak on and I've replaced swingarms or welded broken mounts on at least a dozen bikes myself. You do some reading you'll find all lowering block kits come with big disclaimers about voiding warranties on related parts.
Enjoy,
https://www.hdforums.com/forum/gener...-swingarm.html
Your pictures are of a 2001 and down swing arm. Hollow tube arm woit a small, round adjuster. No support for the axle nut etc. Those arms were junk and several have broken with and w/o lowering blocks. Lowering block and leverage could have contributed to the break with that style swing arm but others of that vintage broke also, same place that didn't use blocks. The 2002 up arm is stronger and completely different.
OP, I ran 1" lowering blocks with a 13" shock on my 2002 FLHTC for 15 years with no problem. Never a sign of an issue (and I checked often). The 13" rode better than a 12". Give it a try, you can always remove them. Just understand, the bike will sit lower.
Softy 103 (03-19-2019)
Old 03-19-2019, 02:01 PM
dyna rider's Avatar
dyna rider
dyna rider is offline
Default 12" Ohlins
Just buy the 12" Ohlins and you will be fine. Ohlins makes an outstanding shock and while an inch more travel would be good, the 12" shocks will work just fine. I just recently put the 13" 772s on my touring bike and it really makes a big difference.
Old 03-19-2019, 02:56 PM
bmaier's Avatar
bmaier
bmaier is offline
The Ohlins 2-2A from Motorcycle Metal are 12" shocks with 3.25" travel. Just as much travel as the 13" shocks but sit at 11" height with sag correctly set.
Old 03-19-2019, 03:08 PM
PFWiz's Avatar
PFWiz
PFWiz is offline
I had over 30,000 miles on my RGU running Ohlin 3-3s from Howard and lowering blocks. When I bought the new CVO Limited I sent the shocks back to Howard to be rebuilt and then installed them and the blocks on the new bike. 7,000 plus trouble free miles on that....
Old 03-19-2019, 03:15 PM
LABoomer's Avatar
LABoomer
LABoomer is offline
Thanks for the input guys. At this point I think the best thing I can do is give Howard a call. With his experience I'm pretty sure he would be able to come up with a setup for me.
Old 03-19-2019, 04:07 PM
Softy 103's Avatar
Softy 103
Softy 103 is offline
Being someone who has had experience with Ohlins I would recommend the pro actions
Old 03-20-2019, 07:18 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,853 Likes on 2,420 Posts
Wink
It is long overdue, but at last there are indeed some decent alternative brands for us at long last.
Old 03-20-2019, 07:31 AM
TwiZted Biker
I've been considering the Ohlins for my RK , your thoughts on the pro actions over them before I spend money ? Solo riding, mostly commuting but do like my twisties which we have in abundance around here.
Quick Reply: Ohlins With Lowering Blocks
