which tpms would you buy
  #111
Old 01-02-2020, 09:49 PM
offbeatmammal's Avatar
offbeatmammal
offbeatmammal is offline
yup, looks like no tracking. For stopping the app, I usually just swipe it closed from the task list (does the same as killing it that way) but also make sure you stop the service if it's showing in your notifications.
Happy (and safe) riding!
MotoJockey (01-02-2020)
  #112
Old 01-04-2020, 08:10 AM
pgpn's Avatar
pgpn
pgpn is offline
Originally Posted by RK_Classic
Good lord, what ever happened to old school mechanical ****!!! throw it in your bag and forget about it.
rk classic.
everytime you check air pressure you run the risk of the valve not seating right causing air loss,
  #113
Old 05-10-2020, 11:01 AM
TriGeezer's Avatar
TriGeezer
TriGeezer is offline
Received 29,353 Likes on 11,172 Posts
I wish I had installed the tvalve and will at the next tire change. I removed my 1 year old FOBOs to top off the air. I must have cocked the rear one when installing it, because the center thing that depresses the valve broke off, and now no workie. Had to buy a new pair for $115, otherwise I was happy with them.
  #114
Old 05-10-2020, 06:46 PM
offbeatmammal
before you buy a new set, check with support ... they may be able to sell you a single unit
  #115
Old 05-10-2020, 09:21 PM
Redlegvzv's Avatar
Redlegvzv
Redlegvzv is offline
I have the FOBO2 system and absolutely love it. I get warnings through my Garmin GPS. It is great being able to check the pressure every time I get on or off the bike just by glancing at my iPhone. The FOBO2 caps are tiny and light -- you do not need metal valve stems with them. They weigh the same or less than steel valve caps.
  #116
Old 05-10-2020, 09:23 PM
MotoJockey's Avatar
MotoJockey
MotoJockey is online now
Received 3,094 Likes on 1,268 Posts
Or, I'll sell you my set for $75 shipped and you'll have a spare........
  #117
Old 04-28-2021, 05:35 PM
HuntWhenever's Avatar
HuntWhenever
HuntWhenever is offline
Originally Posted by binford6100
I had this system installed at the dealer and have been very happy with it. The sensors are mounted inside and the app on my iPhone will alert me if either tire is outside of the pressure limits I’ve set.
http://techbyblu.com/products.html
I'm looking at using these same exact sensors (BLU internal sensors). Has anyone been using these and can offer any feedback? Any update from @binford6100 ?
  #118
Old 04-28-2021, 08:13 PM
Snowfan's Avatar
Snowfan
Snowfan is offline
I got mine on Amazon. Works great. Bluetooth and has temps and programmable alarms. If my tires get hot or too low pressure (28) it beeps. 60 bucks. Its on my handlebar here but I double sticky taped it to my dash and is out of the way.
Amazon Amazon
  #119
Old 04-28-2021, 11:21 PM
TriGeezer's Avatar
TriGeezer
I have the FOBO 2 TPMS, amd am very pleased with it. It works via an app on your phone.
Also, make sure you use metal valve stems. And it helps to use a T valve...that way you don’t have to remove the TPMS to add air.
FOBO Bike 2 tire Pressure Monitoring System (Black) – External Monitor, Bike tire, Temperature Sensor, Wireless, for Smart Bike, Motorcycle, ebike & Bicycle
by AWEGOO
Learn more:
Amazon Amazon
william r
Wheels/Tires
06-20-2017 09:54 AM
Toliverpeterson
2014-2023 Touring Models
11-07-2016 05:03 AM
ByeGoneRider
Screamin Eagle CVO Models
17
01-05-2016 11:08 AM
Doublerunner
09-14-2013 05:31 PM
confused
07-17-2008 05:51 PM
Quick Reply: which tpms would you buy
