Clutch Noise
Old 05-01-2019, 02:52 PM
EvMason's Avatar
EvMason
EvMason is offline
Stage II
Default Clutch Noise
2013 Road King
At 70+mph and shifting into 6th gear, there is a metal connection “clap” noise when the clutch is engaged in gear. Everything else is fine. I’ve had 5 Harley’s never heard or felt this before. I can pull clutch and engage over and over and it keeps clicking like it’s making a connection. What is this noise?
Old 05-01-2019, 04:10 PM
btsom's Avatar
btsom
btsom is offline
If this only happens in 6th gear, I would suspect something about 6th gear, rather than the clutch. Have you tried opening and closing the throttle while in 6th, clutch lever released to see if the noise repeats as the transmission goes from drive to coast? Try the same test while pulling on the clutch lever only enough to remove any play in the cable or master cylinder before the clutch begins to release. Any movement in the lever while transitioning from drive to coast and back would indicate sideward movement of the shaft the clutch is mounted to caused by a worn thrust bearing. Had the derby cove off to see if anything looks unusual? I don't believe there is anything about the clutch that "cares" what gear the transmission is in.
EvMason (05-01-2019)
Old 05-01-2019, 04:37 PM
EvMason's Avatar
EvMason
EvMason is offline
Stage II
Default It’s strange
It only happens when I let out the clutch is sixth. I’ve tried opening and closing.. comps seems good chain slack seems good.. bugging me.
Old 05-01-2019, 08:22 PM
btsom's Avatar
btsom
btsom is offline
I am officially stumped. It may help someone else to know how many miles, hydraulic or cable clutch, any modifications such as taller handle bars requiring a clutch cable or hydraulic line change? If it is a cable clutch, how many miles since the last adjustment inside the derby cover made?
Firebird1989
05-24-2016 04:33 PM
Toner123
02-28-2016 12:30 AM
dyna2010
09-06-2015 09:35 AM
Jplumbob
08-10-2015 07:33 AM
502sport
03-13-2012 09:07 AM
Quick Reply: Clutch Noise
