Gas tank bolts
Old 05-14-2019, 08:31 AM
rysonn's Avatar
rysonn
rysonn is offline
Default Gas tank bolts
Just picked up a new to me 09 SG. I am going to be running some amp wires under the tank. It appears that the previous owner may have done some slight stripping of the front tank bolts when they ran wires for auxiliary lights. Given that I don't want to make this any worse, can someone tell me what size torx is supposed to be used on those front bolts for the gas tank? I want to make sure I get it right on the first shot.
Thanks everyone!
Old 05-14-2019, 09:17 AM
skydude426's Avatar
skydude426
skydude426 is offline
If those bolts are stock, they should be dual torx and standard 1/2” socket. If you want a cleaner look, try these.
https://colonyusa.com/products/harle...-chrome-2106-4
Old 05-14-2019, 09:27 AM
rysonn's Avatar
rysonn
rysonn is offline
Dual torx? Is it like a t40 or something?
Old 05-14-2019, 09:36 AM
hattitude's Avatar
hattitude
hattitude is online now
Received 7,413 Likes on 4,017 Posts
That means they can take a T40 or a 1/2" SAE socket.... you can use two different drives, dual use...
OEM bolt is part #3634, and uses either T40 torx drive or 1/2" SAE socket
If your torx portion has been messed up, use the 1/2" socket.... that is, if they are still OEM bolts...
Old 05-14-2019, 09:38 AM
rysonn's Avatar
rysonn
rysonn is offline
Ohhhhhhhh I gotcha. Ok that makes sense. I will look again. On the surface I want to say that they were rounded heads and not socket but I will check again when I get home.
kculp
06-01-2017 07:52 AM
OriginOfEvil
05-02-2013 01:43 PM
doublenaughtspy
09-30-2010 06:43 PM
lkbenson
06-01-2006 02:29 AM
Rocket Man
02-18-2006 10:33 PM
Quick Reply: Gas tank bolts
