2016 RG vs RG Special
In 2016, what was the difference between the Road Glide and Road Glide Special?
Special has pinstripes, 6.5 radio standard, ABS linked brakes standard, black painted inner fairing and rear shocks.
Check me but, isn’t the rear shock system different. The special has the rebound adjustable. The standard model has air shocks.
Originally Posted by Dsm Limited
(Post 18318209)
Special has pinstripes, 6.5 radio standard, ABS linked brakes standard, and black painted inner fairing. Might be a couple other difference, that I missed.
Yes, you forgot the lot lighter wallet... lol |
I thought the specials had different bags as well that hung below the exhaust pipe.
Maybe not on the 2016 Specials. Might be a newer thing. |
........ Specials have always had the extended bags
Originally Posted by groupw
(Post 18319254)
Hand adjustable shocks, pin stripes, 6.5 radio, painted inner fairing, linked abs brakes were all standard on the specials. These were the only differences I believe. If you are looking at buying one or the other you can buy a standard and make it a special with the exception of the pin stripes cheaper than the typical cost difference. Check the classifieds and you can get the radio and shocks cheap.
Shocks
Originally Posted by Taggs
(Post 18318375)
(Post 18318375)
This is true..... i forgot about the shock difference. I will edit my original post, thanks for that. |
© 2024 MH Sub I, LLC dba Internet Brands
