RPMs not matching speed.
I have a 2018 Ultra Limited with 22000 miles and when accelerating it feels like the RPMs are to high for the the speed almost like a clutch slipping but not really. I dropped it off at the dealership and they are going to look at it.
Any ideas?
Any ideas?
For the purposes of troubleshooting, it's hard to say with nothing more than what you posted, but....
Did it just start happening, or did you "work on/change" something and then it started?
Is your driving style hard on the clutch? Do you slip the clutch a lot? Do do drive it hard? Do you like fast starts? Do you like doing burnouts?
Regardless of the above, any time I suspect a clutch issue I start with the below steps:
On a cable clutch, I check the clutch adjustment and clutch cable for wear/issues...
On a hydraulic clutch, I check the fluid level, check for leaks in the system, and check to make sure the fluid has been flushed within a 2-3yr period...
Let us know what the dealer says...
Doesnt sound that strange. My cvo limited runs around 2000 rpm in 6th gear around 60 mph. I run a 131 engine.
Bafflingbs (09-06-2020)
And crank runout, if lugging too much, I believe. I’ve been told that is not a good thing, for a Harley. Especially for a bigger engine.
GPHDXLC (09-09-2020)
The following 2 users liked this post by barneyboy:
lp (09-07-2020),
Peter Quinn (09-08-2020)
