I have had my Road Glide on a tender for a while. Today the tender started blinking "check battery." I turned the bike to start it up and noticed the gauge only goes to 10ish, as shown in the pic. It started fine though and the gauge went to 14ish when running. However, I can't remember what it usually says before starting. Is this normal? Or sign of a bad battery? Battery is about 2.5 years old, only about 3k miles on it.
I just wanted to check on this so I don't get stranded.
Thanks!
Should be a minimum of 12v. Best measured at battery with everything off. My bike shows 12.5v key on/engine off. Note that on this chart, you're out of the acceptable state of charge below 12v.
After sitting for a while, with the tender attached, With the ignition on, and the run switch on, mine reads 12.7 with a dmm at the battery tail lead. The built in gauge is not extremely accurate, so use a dmm or buy one of these....
YONHAN 4.8A Motorcycle USB Charger SAE to USB Adapter with Voltmeter & ON/Off Switch, 3 Install Options Waterproof Quick Disconnect Plug for Smart Phone Tablet GPS by YONHAN Learn more:
