06 Road King lights all flashing
I was moving my Road King Classic around the garage the other day (the key fob was in the house) and ALL of the lights started flashing, randomly. The alarm was not set and has never been used. I put a new battery in the key fob, turned the key on and the lights are all still flashing, randomly. Is there a pin code that needs to be entered? If so, how? thanks in advance for any and all help. regards, Bob
Is the battery the correct on (CR2032) if so open the fob and make sure the plus side of the battery is pointing up, you may have put it in upside down, if you did not know the code before hand not sure you can retrieve it without a good working fob. I'm sure others will chime in.
rk classic.
rk classic.
If the fob and security system is arming and disarmngthen entering the pin code will make no difference. As soon as the fob is "seen" by the bike the security is disarmed when the ignition is turned on usually evidenced by not seeing PIN on the speedo display.
