Before '13 bag lids
Before '13 bag lids
So as all of you know how the bag lids on '13 and before is the two-hand operation and I never have liked that.
Have any of you guys used any of the kits out there to convert them to opening more like the later models? If so which did you use and how did it work? Thanks
Received 1,566 Likes
I've never heard of aanyoneswapping to the newer style lids on older bags. However, I have seen in person, guys swapping to the newer bag with little modification to the bag mount system. The pins that hold the bags are slightly off from the 13 to the 14, and can be adjusted enough to allow the newer style bag to fit on the older frame.
broke c7 (04-24-2023)
I have a ‘97 RK, OEM bags.
I bought a set of the Amazon bags for my ‘01 RKC, they have the one hand operation.
I much prefer the oem bags, they are a bit larger. The one hand latches have fixed rings inside that the tops latch to, they take up a lot of room inside the bags.
The after market tops do not lay out 180° when opened, more like 90 - 100°. I use the fabric tether like a mini table on the oem bags.
The aftermarket bags are made of thinner material. They rattle a bit when not fully loaded… my bags are usually fully loaded, so this is a minor gripe.
The locks are cheesy and don’t operate as smoothly as the oem locks.
The finish had a couple blemishes, I complained and they issued a $110 refund… so for < $100 I have hard bags.
THE AFTERMARKET HARD BAGS ARE A HUGE UPGRADE OVER THE OEM LEATHER BAGS THAT COME ON THE RK CLASSIC!!
The black aftermarket bags don’t look bad on the blue ‘01
I picked up a set of older style oem bags to replace the Amazon bags… I just need to paint them to match.
Santo
Gear and Other Items For Sale
13
05-27-2015 07:02 AM
