oil cooler
BadBokOK.....oil coolers don't do much of any good when you are stuck in traffic, they are made to keep the engine a bit cooler when running down the highway and you have a good air-flow over the cooling fins. On hot days running at highway speed you can keep your oil 20 or more degrees cooler than it otherwise would be. There is lots of controversary over whether they are needed or not, but I figured as hot as the 96" engine runs it couldn't hurt.
The oil cooler is supposed to drop the oil temperature approxiamtely 20 degrees, which is a good thing. Running in cooler temperatures it is important to cover the oil cooler, get a thermostat, or a manual shut off. I elected the manual shut off as the thermostat is generally the weak point in the oil cooler. They can stick on or off as they age.
Buells come with coolers as well as most BMWs. They are standard on many cars.
I am sure that there are just as many people that say oil coolers are not necessary. Many also think that the clamps for the cooler are a point for leaks. If you check them periodically that should not be an issue. If you change your oil faithfully and use a good quality of oil one should not have any problems. I have used synthetic in all of my bikes as they have worked well for me. I just believe the synthetics do not break down as fast as the conventional oils, but that is an entirely separate discussion.
I hope my thoughts have helped you. The vry best.
I am thinking about an oil cooler for my 08 SG. Looking for pros and cons and types of coolers that you all might think is the best. I do alot of cross country riding as a matter of fact this year I went 9200 miles in 6 weeks on one trip. N.Y. to New Mexico then up to Washington then to Wyoming then to Colorado and Back to NY. Thats the kind of riding I like to do. Many different weather patterns.
HD Premium: This is what I installed and is working perfectly. Has thermostat in in the kit and is a low-mount.
Jagg vertical: Fits on left downtube. Thermostat optional, or buy a manual cut-off valve.
Jagg 10-row: Also fits on left downtube and has more rows than either of the above. Thermostat optional, or buy a manual cut-off valve. Available low or vertical mount.
Chrome-plated bling "coolers": Not really coolers, but heatsinks and likely won't perform nearly as well as a real cooler but are less expensive. Same issue with thermostat/valve.
The thermostat is important, IMO, as an air-cooled engine has enough trouble getting up to operating temperature having no internal controls on heat retension during warm-up. Prolonging the warm-up is hard on the engine and the oil.
BTW, coolers do work to some degree in traffic with low airflow due to convection, and every little bit helps. Getting a grip on A/F ratios helps too, as in stock form you are likely running quite lean, even with a Stage 1 download, especially with '07 and later closed-loop systems.
I've got the HD premium oil cooler on my 08 Ultra. Got the bike in October, so haven't ridden in hot weather yet. The only thing I would recommend is the whichever model you buy get one thant is thermostatically controlled....the HD cooler doesn't run oil to it until the engine temp reaches 185 degrees, this helps make sure the engine gets a chance to reach required operating temperature especially when you ride in cooler weather.
Don't think it has a thermostat. Have had it apart (was loose) and no internals to it other than the passages. Should it be changed?
