Ambient air gauge is classic Harley ploy
Old 03-08-2008, 08:05 PM
Uncle Scrooge's Avatar
Uncle Scrooge
Uncle Scrooge is offline
Default Ambient air gauge is classic Harley ploy
I've been following the various posts on how inaccurate the ambient air gauge is. Mine is too. So I took the outer fairing off today to see about relocatingthe sensor in order to improve accuracy.I don't see a solution, at least not one that would be worth the trouble. The sensor doesn't appear to be designed to withstand rain and it's not attractive at all, so moving it to an exposed,visible spot is out. Moving it to a protected, less visible spot in front of the motor probablywon't improve accuracymuch, due to engine heat.
Then it hit me! This is a classic example of Harley's time-tested marketing technique--sell us a situation that is not quite right and then sell usthe fix. The air temp gauge is pretty much useless, but you can make it right by replacing it with an oil temp gauge for $139.95.
Old 03-08-2008, 08:13 PM
Beemervet's Avatar
Beemervet
Beemervet is offline
Default RE: Ambient air gauge is classic Harley ploy
Ummmmmmm......did you just figure that out, or are you the real Mr. Obvious?
Old 03-08-2008, 08:14 PM
captjon37's Avatar
captjon37
captjon37 is offline
Yes, its a conspiracy and you will do what they want you to do.
Old 03-08-2008, 08:20 PM
StreetGlider56's Avatar
StreetGlider56
StreetGlider56 is offline
You WILL be assimilated...
[IMG]local://upfiles/11910/2793DD61B1364AE6B7A891850A75E031.jpg[/IMG]
Old 03-08-2008, 08:22 PM
Drifting Texas's Avatar
Drifting Texas
Drifting Texas is offline
ORIGINAL: Uncle Scrooge
Just move the probe outside the fairing. Put it under the fairing between the forks. You will be surprised.
Garemlin's Avatar
Garemlin
Garemlin is offline
Comply or die!!!!!!!!!!!!!!!!
BIGCHIEF's Avatar
BIGCHIEF
BIGCHIEF is offline
Move it to the lower cross bar afteradding about 10" of wire. It is not really visible unless you are looking and it works relatively well. (Relatively means within 5 degrees.)
Old 03-08-2008, 08:26 PM
Pastor John's Avatar
Pastor John
Pastor John is offline
Seene more reason to own a Road Glide - mine works perfectly!
Old 03-08-2008, 08:28 PM
EasternSP's Avatar
EasternSP
EasternSP is offline
Received 22,403 Likes on 8,586 Posts
God will strike you down for lying there Pastor J. 8-)
Old 03-08-2008, 08:33 PM
Ram's Avatar
Ram
Ram is offline
I'm sure that you don't want to just leave that sensor in place and drill a hole in the fairing to allow the proper air flow to it?
Quick Reply: Ambient air gauge is classic Harley ploy
