Got a ? for the electricial types out there
I want to hard wire the power for my GPS which is 5 volts.
Question is: is the resistor for the power plug in the housing or is it the part on the cord I have circled? I dont want to bust this thing up until I know.
Thanks Guys
[IMG]local://upfiles/19036/EF44FDEAF6794556B2F41463F2519FCF.jpg[/IMG]
Thanks Guys
RE: Got a ? for the electricial types out there
Yea, hard to tell for sure, One way would be take a volt meter and measure the voltage on both sides of that "Resistor" looking thing. (If your SURE you want it hard wired, cut that off with wire to spare on both sides, measure the voltage before it from the accessory plug. If it's still 5vdc then the step down resistor is in the plug. Resistance and voltage drop is not real hard to figure with "ohms law" (It would take some refreshing on my part, been a while since I had to "Design a circut" ,,, like basic E&E school in Millington, Tn.)
I think that little fat thing is a voltage reducer. Is that the same as a resistor - don't know? Check out this website - they might have what you need for hard wiring
http://www.cycoactive.com/gps/powint.htm
The thing that's circled looks like an RF choke - meaning an alternator noise suppressor. The voltage regulator is usually a 3 legged IC that looks like a large (relatively) transistor. 12v in, 5v out. It is probably built in to the cig lighter ***'y. Why they don't build stuff to work right off 12v is a mystery to me other than wanting to sell the regulator I guess.
ORIGINAL: FLHT
Thanks Guys
Thanks Guys
ORIGINAL: FLHT
Thanks Guys
Thanks Guys
