DYNO Numbers for Baggers???
#4171
#4172
FM 107 build, installed and dyno'd by FM
TW-555
10.5 CR
FM Level B Heads
FM Adjustable Pushrods
MGS True Duals
Arlen Ness Big Sucker
FM Power Vision
Before and After on same plot. Before was just the "Stage 1" (MGS pipes, Big Sucker, PV)
109.77 HP, 126.69 TQ
Up from 78.18 HP, 95.51 TQ.
![](http://i813.photobucket.com/albums/zz57/jlj6t/107JohnstonBeforeAft.jpg)
TW-555
10.5 CR
FM Level B Heads
MGS True Duals
FM Power Vision
![Big Grin](https://www.hdforums.com/forum/images/smilies/biggrin.gif)
#4174
TW-555
10.5 CR
FM Level B Heads
MGS True Duals
FM Power Vision
TW-555
10.5 CR
FM Level B Heads
MGS True Duals
FM Power Vision
#4175
#4176
Here's my build: 09 FLHTC, 103, SE 255 cams, SE air cleaner, Freedom Performance true duals, Power Commander 5, stock map.
Just had the bike dynoed yesterday. 86.21 HP, 101.66 Torque.
Was hoping the HP number would have been higher, but the torque number is OK I think for only some very basic mods and no custom map.
#4177
#4178
![Wink](https://www.hdforums.com/forum/images/icons/icon12.gif)
It used to be the case that HP and TQ numbers in a good tune were the same, but more recently larger TQ numbers are becoming normal, which goes hand in hand with higher low/mid range torque. That is what gets us moving off the line fast and passing traffic effortlessly! Our cam designers and engine tuners are changing the shape of our torque curves for the better.
#4179
#4180
Put a good exhaust on it and you'll see some better gains. You have to big a TB, especially for those pipes. Your HP flattens out around 5k RPM's which is a sign that your engines not breathing very good. A good breathing build should show the HP climbing all the way to the rev limiter.
