Tap into 12v wiring up front
Hi,
I am getting set to wire up my new Zumo 550 and was looking for some suggestions as to what wires I could tap into for 12 volt power inside the nacelle. I have all the connectors that I need (I think), I just need to know which is the best + and - wires without digging through the manual.  \\; This is an edit: I thought I should go back to the original post and mention that this is a 2000 Road King. It seems it has a different wiring harness than the one that responders have been referencing. Thanks, Murph |
RE: Tap into 12v wiring up front
I should have taken pictures, but it is quite easy. I bought two small blade connectors to put on the Zumo leads and they plugged right into the open spare connectors behind the headlight. I just pulled off the windshield and the fairing, plugged it in and it was done. Be careful with the the lower left screw that attaches the fairing. I lost the sucker and I was lucky to get the last one at the dealer.
Thanks, I guess I'm going to have to dig out my 12 volt tester and see which wires turn on and off with the ignition and accessories switch.
Murph |
behind the head lights there should be a spade connector with a red boot on it
 \\; used for the fender tip light i used it for my powered antenna-ride safe |
why not use the acc switch to wire it up?
The terminals at the back of my acc switch broke off, so my buddy wired it for continuous supply. \\;So I guess if I understand you, I could tap into that continous supply for my + and find another ground for the - \\; ??
Thanks, Murph |
There is always the ciggy lighter
Don't need the ACC switch.
Cheapest trip ever to the dealership.
The connections are obvious and switch on and off with the main power.
© 2024 MH Sub I, LLC dba Internet Brands
