XM MYFI on streetglide
I did before I went to the HD XM. All you need is the car kit cradle and one of the ram mounts. You can put the antenna under the fairing if you like and then run a wire to the back of the cradle to the AUX input on the radio along with the antenna wire. You don't have to unhook any wires when you remove it just slip the Myfi into the cradle and it's ready to go. I had a 10in 1/8 to 1/8 male on both end cable made so you don't have to hide a bunch of wires. Hope this helps
Ive been stalking this sight for a couple of weeks, but this subject hit home so I signed up. Ive used a MyFy on my 99 EG std for about 3 years now. I mounted the car cradle like mentioned before and put the antenna inside the fairing. I also wired in a cig lighter socket from the car parts store inside the fairing to hide more wiring and used the aux cd port on the HD radio...
I only had 2 problems with this set up.
1 I had a slight whine noise.
2 The vibration of the HDs, that we all enjoy, finally wore out the earphone connection on the MyFy.
So Im in the market for a new type portable xm radio and will have it ready to adapt to my 010 RG.
Matt
Matt
Matt
Matt
Thanks! I'll get on the bay and check it out. I like the MyFi because it's very portable. I can use it on the bike,in the garage,when I run etc. I would use the earphone outlet of the MyFi on the bike because I could adjust the volume higher than on the aux outlet.
This is a great sight, Im glad I ran across it.
I have a XM and like Trock use the AUX jack in the radio. I mounted mine in one of the HD windshield 2 pocket pouches. I also mounted a seperate cig lighter up higher on the fairing. I was worried that the male plug could hit the gas tank from the factory cig location on my Street Glide. I dont like dents. The antenna rest under one of the leather flaps. Works great. I transfer it to my bass boat or...now that its winter I have it hooked up in my shop.
Bad news......XM rates are going up $2 a month and no more free online listening, that cost now will be $2.99 additional.
About that merger between XM and Sirius, I would not go to far out with a plan with these guys. 3 Monthes at a time for me max.
