Starting the EFI Harley Davidson motorcycle
In the 06" touring owners manual....
1) Turn ignition/headlamp key switch to ignition position. Do not roll the throttle
NOTE
The engine lamp will light for approximately 4 seconds and you will hear the fuel pump purr for approximately 2 seconds as it oeperates to fill the fuel lines with gasoline.
2) turn the off/run switch to run position
3) Press the starter button to start motorcycle
PS...I use this method and I also have the PCIII installed........
NOTE
I'm one that has a PCIII and the starter makes a lot of noise on hot starts. I also was one that waited for all the lights to cycle.
In the last week or so I've changed to hit the switch and crank her up. What do you know, no more noise.
Yea, my salesman said to wait, now I can't wait to get home to read the owners manual for myself.
2004 Touring Models Owner's Manual
1. Put the off/run switch in the RUN position and the transmission in nuetral.Nuetral (green) indicator lamp should be illuminated.
2. Turn ignition /headlamp key switch to ON and push the START switch to operate starter motor.
That's it.Nothing about waiting for anything.
As for as the dealership saying to wait with nothing in the manuals to back it up....kinda like how they also say to bring your scoot in every 2.5k miles to change all the fluids,with nothing said like that in the manuals.
I will try to be as simplistic as possible, All fuel injected vehicles run on a pressurized system. When you shut the engine down a injection system will remain pressurized for a long period of time, this is why the motor will start right away if your EFI system is in good repair. The Mo cos concern is that if your EFI system is not 100 % it may bleed of pressure and premature starts may fail and flooding of the motor or worse may happen leaving you stranded and with a hefty repair bill. I could wright another page on this but I hope this is a simple over view.
guys, i don't know if you noticed this or not, but the check engine light does not illuminate until you flip the run/off switch into the run position.......
NOTE
NOTE
NOTE
NOTE
which experts would you be referring to? the ones that said that synthetic oil causes bearing skate?
thats why i said to wait until the computer resets before hitting the run/off switch to run. give the computer time to reset, then hit the switch to run, give it a second to pressurize, hit the start button.....
so do you wait or not? it doesn't say anything about waiting, it just says that the lamp will light for 4 seconds......
I wait..I turn on the run switch....turn on the ignition switch..wait for the light to go off...then start the bike....
