headlight bulb replacement
That was my plan. I e-mailed Candlepower Inc. twice in the last three weeks with some product info questions and have yet to hear back from them.
Spend another $35 or so and replace the mediocre non-fluted stock headlight with these E-Code lamps (European code). They provide much improvement to not only "seeing distance" but the pattern of the light on both high- and low-beams. These lamps don't look as cool as stock and have fluted lenses, but if function is more important than cosmetics these are a winner, especially for the money spent. After upgrading to these nobody has mentioned the headlight appearance and I don't see it as a cosmetic detraction, but YMMV.
Do I need to alter anything or is just ordering these to items all I need?
Plus, I currently run the Gerbring Heated Gloves. I want to add driving lights.
How much will my stock alternator take?
Thanks
If you add driving lights I would connect them via a relay to take the stress off the headlight circuit. In stock form the passing lamps on most FLH's are connected directly to the low-beam circuit with no relay, and IMO that might be a bit much for the connector and wiring if you add another 6A to it. Connecting the driving lights with a relay, secondary (switching) circuit on the low- or high-beams and primary directly to the battery with a dedicated 15A fuse, would be the best method even if you don't upgrade to the 80/100W H4 bulbs.
As a warning, the low-beam pattern of the E-code lamps has a sharp cut-off which is good for night riding but makes the light almost invisible to oncoming vehicles in daylight, so when using the E-code lights you should always have it switched to high-beam in the daytime. I also added a modulator (Kisan Pathblazer) which works only in daylight and makes the bike much more visible by pulsating the high-beam at 20/100% 4x/sec. It also makes the bulb run cooler which increases its lifespan (high-beam filament only), and I go years between bulb changes with the Hella 80/100W bulbs. IMO package this is the best bang-for-the-buck headlight mod available.
Have had mine now for over a year. Talking about bright! Wow! I've turned all my riding pals onto this bulb and everyone is more than happy with end results. Originally for off road vehicles, but does my Road King wonders for being seen (daytime) and seeing at night.
http://www.germanautoparts.com/Hardware/Bulbs/H4
Is this the bulb you run?
And for the switching, you are saying get a relay and a 15 amp fuse connected to the battery then connect to the low or high beams. Correct? How do I determine which relay to get.
Thanks Iclick, you are always helpful.
