Changing fluids while on a center stand?
Old Sep 3, 2009 | 11:50 AM
Kenan's Avatar
Kenan
Default Changing fluids while on a center stand?
I don't have a center stand or a lift yet. I'm trying to decide if I want a lift to change all the fluilds or can everything be done while sitting on a center stand? Any thoughts?
Old Sep 3, 2009 | 11:58 AM
piasspj's Avatar
piasspj
Depends on how often you change fluids and if you like laying on the ground.
A center stand (mounted to the bike) will hold the bike upright. A wheel chock (or a couple straps) will do the same and are cheaper but aren't attached to the bike.
A Jack will raise the bike up, making it easier to get at the underside of the bike.
A table lift will raise the bike up higher, making it even easier to work.
None are required for fluid changes, each device has advantages and disadvantages.
Old Sep 3, 2009 | 12:29 PM
THABULL's Avatar
THABULL
Fluids need to be drained with the bike upright! A jack is nice for most everything but with a fluid change no where to put a catch pan. I have a condor dock I ride mine up into and just lie on the garage floor , and use cheap turkey pan from the grocery store to catch the fluids!
Old Sep 3, 2009 | 12:34 PM
db2753's Avatar
db2753
According to my manual, the crankcase oil should be changed leaning on the jiffy stand. The Primary & Trans are upright and I have the Wheeldock Center Stand for that and works great. I gave away my jack after I put on my center stand.
Old Sep 3, 2009 | 01:02 PM
Orion1369's Avatar
Orion1369
I have centerstands on my both my Road Glide and the wife's Electra Glide. They really are nice for washing, checking tires, parking close together, and loading when we are getting ready to hit the road. I also have a table lift for doing my maintenance and it is well worth the money. After just one service on each bike and one rear tire change, the cost had been absorbed. Now any time I want to just put it on the lift to get it in the air to polish I can and any service is done not laying on the floor.
Old Sep 3, 2009 | 01:26 PM
xxxflhrci's Avatar
xxxflhrci
A lift isn't needed for changing fluids. IMO, doing it on the side stand is just as easy. A lift only gets in the way of your drain pain. Some people seem to find it tough finding a drain pain to slide under their bike. I use an anti-freeze jug with the side cut out. That's not to say that you won't want a lift for other jobs. I like mine even for washing/waxing, just not changing the oil.
Old Sep 3, 2009 | 01:38 PM
iclick's Avatar
iclick
I use Xxxflhrci's method of changing on the side-stand, but after the engine and tranny drain I right the bike and let them drain completely, which takes only a short time. The primary oil will drain completely on the kickstand. I agree that lifts get in the way and I don't mind lying on a bath mat on the garage floor. I use some old photo-chemical trays (16x20" is best), which are shallow, but my regular oil drain pan I use for the car won't fit. Xxxflhrci's idea of a turkey pan sounds like a good one. I buy oil by the 5-gal. pail to save money and use the empties to collect the used oil, then take the pails to a recycling area to dump it.
Old Sep 3, 2009 | 01:40 PM
xxxflhrci's Avatar
xxxflhrci
Heck, I have carpet down in my entire garage. Laying on the floor is no big deal.
Old Sep 3, 2009 | 02:53 PM
beary's Avatar
beary
I agree that the manual says to change the crankcase oil on the jiffy stand, but you will get another 3rd to 1/2 quart when it is up right. As was said, just sit on the bike and hold it up right a couple minutes.
Beary
Old Sep 3, 2009 | 04:07 PM
xxxflhrci's Avatar
xxxflhrci
I don't see how standing the bike upright is gonna get out another 1/3 to 1/2 quart of engine oil. The drain plug is on a corner and is the lowest spot in the pan when the bike is on the side stand.
jrat69
Mar 16, 2016 11:46 PM
DaveNBPT
Sep 15, 2014 08:29 AM
spizzyman
Sep 1, 2008 09:15 PM
Chilhowee
Mar 24, 2008 11:48 AM
06EGlide
Feb 5, 2008 08:38 AM
