Fuel Pak Users ?
On my 09 Ultra do I input all 35 modes when setting the fuel pak or just the firsts 18 like the instructions say?? Its the Version 13.
Thanks |
I was looking at the instructions for the 09 touring and it looks like you enter the values for 1 thru 18 and 34 & 35 for version #13 and up. Also verify 21 is at 0.
Thanks tibadoe - Looks like that may be the case. Could not figure why they were more codes on the instruction sheet in the 2nd column. Appreciate the feedback.
Thanks |
No problem. Let me know how you like it. I was deciding between the fuelpak or the pcv. I am adding the big shot duals with a "modified" quiet baffle. Don't know if V&H will be able to tell me how to fine tune with my changes by adding more back pressure.
It only takes about 1 minute to cycle through them. After I did mine the first time I cycled through the sequence a second time to verify I put all the values in correctly.
Originally Posted by tibadoe
(Post 5541466)
Thanks for the info guys but why is there settings for 23 thru 35? Even in the fuel pak itself is numbers in the mode settings. Think I should set them to 0's?
Thanks for the replys. |
Originally Posted by ultrarex09
(Post 5542624)
© 2024 MH Sub I, LLC dba Internet Brands
