Marbles in coffee can
Brilliant me decides to ride from McKinney to Oklahoma city this past weekend. Learned about Frogg Toggs the hard way. Drenched the entire way home. Bike ran perfectly there and back. Pull in the driveway, park to open garage door and bike sounded like it had marbles in a coffee can while at idle. I am running syn 3 in all 3 since 1k service and bike just hit 3k. Never have heard this before. I know some think syn 3 is trash and I will be changing to amsoil soon. What causes the marbles in the can sound?
Thanks for the input. Dunlop 407's were all good thru the monsoon as well.
Not sure, but that sounds like an "expensive" sound. Happened to my buddies RK at the beggining of the season. Dies at a light, finally got started and it made nasty noises from the bottom end like that. Crank bushing went south, took out the oil pump, basicly ruined the bottom end of the motor. Now it's punched out to 103"
Hope that's not what's wrong with your sled.
This sounds reasonable. Bike seemed to run fine the entire time. Never noticed this sound when filling up for gas and other stops. Hoping sound is not there when I fire it up again. I had hesitated just doing slip-ons alone causing the bike to run even more lean, but the majority on the board seemed to think that bike should be fine w/out doing AC and download. Had tiny bit of decel pop sporadically but nothing else out of the ordinary. Thanks for all the input. Jeff
You may have just gotten a bad tank of gas at your last stop - happened to me on one trip, after a few miles after a fill the bike started running rough, kept stalling and wouldn't idle right. Since I was in the middle of nowhere I had no choice so I just ran it hard to the next gas stop, filled it again with a good brand name premium and it ran fine after that.
sounds like it was knocking a bit because the revs were too low to pull the bike up the incline. nothing to worry about. sorta like climbing a steep grade in too tall of a gear, they can hammer, and to avoid that, you just gear it down a gear or two. don't expect it to pull itself into your garage if there is a steep incline going into it at idle. get her revving a little and feather the clutch, should be fine. don't forget to remove that coffee can that has a dozen marbles in it from your left saddlebag. laffin here. ride safe
Damn, I knew I forgot something, . Just to clarify. The bike made the sound at idle while it sat it the driveway prior to pulling into garage. Not while I was actually moving. I just heard it after I got off. Stood there for a minute cuz I thought my ears were playing tricks on me. Bike had never rattled like that before. I am gonna fire it up tonight and see if the sound is still there. Hopefully a 1x thing. Thanks again.
