Road King Braided Clutch Cable
Has anyone had a problem with braided clutch cables wearing through the clear sheathing on the outside of the cable where it runs through the clamp on the front forks? It starts with small nicks which eventually start binding where it slides through the clamp.
The cable is HD Diamond series, a friend also has the same problem with his Barnett cable.
The dealer replaced my braided clutch cable a couple years ago, I had the same problem. They both have a clear tube that is supposed to ride in the clamp but every time your forks move the tube works down the cable. The newer cable is starting get gorned up now. Going to try to get them to come off of another one. Braided cables are not cheap.
If you could post those Pics I would Appreciate it !! I am planning on getting braided cables and would like to route them the best way from the get go... TIA
I had my clutch line routed what i thought was the right way and it started rubbing off after only a few hundred miles. I finally went to a dealer and looked at another bike and saw that the 'P' clamp that attatches to the fork was facing the wrong way. Made all the difference in the world. It is still rubbed from before but it hasn't gotten worse
Yes but mine started to wear where it made contact with the frame under the engine. I had an oil leak I could not find and the dealer discovered that it had wore through and tranny oil was going back down the inside of the cable and leaking out where it was worn. Had to replace the cable and we but a piece of rubber over it and tied it up much better.
