Replaced my front fender
Well I got my new front fender in today (dealer damaged my original one while towing the bike) and I decided I had enough of them touching my bike so even though they damaged it, I would replace it. First time I took on this job and I must say it was a learning experience. I first thought I could just unbolt the fender jack up the bike and rotate the fender around the tire, well nope, the stand offs that the bolts go through wont fit through the forks so you have to take off the wheel and remove the fender from the bottom of the forks. Well I remove the wheel and with out realizing it, the tire hits the brake calipers so I have to remove them as well (dealer gorilla griped those bolts on by the way). So I get that all taken off and put the new fender on. What seemed to be about a 20 minute job turned into an hour and a half, but hey its done correctly. So if you ever have to replace your front fender, learn something from me and remove the calipers and wheel first.
The batwing is quite a bit further away from the fender than the shark nose, maybe more wiggle room, in any event glad you got your fender replaced Chris, without any further dealer 'intervention'
Saturday morning project. Front fender bent Friday morning ( my fault got boxed in by 2 cagers on the way home from work @ 5AM, cager in front swerves at the last minute to miss 18 Wheeler tire, I clipped it ) tire whipped up and bent Fender, so with that said I have to get it off to take to body shop today to get estimate to get fixed. I don't want to pay extra to have body shop remove repair paint and put back on.... So any help would be appreciated.......
