Does your rear whitewall get dirtier than the front?
I noticed that my rear whitewall gets much dirtier than the front. Specifically the RIGHT rear whitewall. At a glance, you might think that something is spraying little streaks of oil on the tire. But a close inspection, reveals no leaks or a sign of anything wet. Just a dirty tire.
Curious if others fond their rear whitewall gets pretty dirty.
Well, if I get down flat on the ground to look at it, yes. I don't scamper around quickly enough to check both sides of the tire but the white wall under the saddle bags is dirtier than the front. But I just ride the heck out of it anyway. Life is too short to worry about dumb ****.
The right side is where the brake caliper is, so the brake dust is more prevalent there. Get some Lyndall dustless brake pads and that should help alleviate the problem.
