HD garage door opener?
Old 10-31-2009, 05:19 PM
fastolds's Avatar
fastolds
fastolds is offline
Default HD garage door opener?
I just bought the HD garage door opener. Anyone have any issues with it?
Old 10-31-2009, 06:15 PM
eagle212a's Avatar
eagle212a
eagle212a is offline
6th Gear
had mine for a couple of years now. it works great. flash the high beams to open/close.
Old 10-31-2009, 07:14 PM
musclehead's Avatar
musclehead
musclehead is offline
I installed one that came with the CVO Ultra. Followed the simple directions in the owner's manual and it work great.
Old 10-31-2009, 07:27 PM
Certified Drunk's Avatar
Certified Drunk
Certified Drunk is offline
What brand of garage door opener do you need?
Old 10-31-2009, 07:38 PM
gunner11's Avatar
gunner11
gunner11 is offline
I just use the original, my hands and arms
Old 10-31-2009, 07:48 PM
Texas Rapier's Avatar
Texas Rapier
Texas Rapier is offline
It should work with any garage door opener. The receiver has two wires on it that connect to the two screws that the inside push button goes on.
When the receiver is activated it closes a connection just like the inside push button does.
Most of today's garage door openers have three screws for connect system wires.
One is for the push button the next is a common and the third is for the safety sensors.
If the screws aren't marked cut a short wire and strip the ends. touch the bare wires to two screws. When you find the two screws that cause the door opener to operate, that is the two screws you want to connect the receiver too.
Old 10-31-2009, 09:35 PM
envexed's Avatar
envexed
envexed is offline
Yes , Issues....mine quit working. I checked the out put of the onboard transmitter with at key fob tool I use at work in the auto dealership; very strong out put.....SO,. the unit connected to the garage opener motor receiver is not working.
A year ago it quit working and I had to relearn it and I started working again, this time It will not. IMHO.......one heck of a product when it worked, very poor quality and didn't last. I hope it's just my unit and not typical, I sure liked using it.
Old 10-31-2009, 10:23 PM
Texas Rapier
What kind of garage door opener do you have?
Old 11-01-2009, 12:00 AM
salty01's Avatar
salty01
salty01 is offline
I heard they work well but I did mine for 5$ and a 1/2 hour of my time with a small push button switch and my extra GDO.
Old 11-01-2009, 01:03 AM
Texas Rapier
So did I. I had a garage door company for ten years and still have a lot of parts laying around.
Solder a wire on both sides of the micro push button on the circuit board. Run those to a momentary switch. Solder wires to the battery terminals and connect to 12 volt power source. program to the operator. Done.
There's one in the fairing of the below pictured Road King.
Quick Reply: HD garage door opener?
