The $169 H-D air horn quit working
I was just reading a few post just a couple of day ago about how much a piece junk the H-D air horn was and I was thinking how lucky I was that mine was still working. Well, that is no longer true.
Are these things repairable or should I just chunk it?. I haven't a clue what's wrong with it. I know it's getting voltage to the connectors.
When the HD Premium Air Horn gets wet, it sounds like a goose in the last throes of life. When it is used in rapid succession, it loses volume like an old dying bleating sheep (too much animal imagery here?).
Toss it.
Not only did I save more than $100 over your own install but my Fiamm Freeway Blasters horns (hi & low tone) work perfect.
They're mounted on both sides of the tank, attached to the front tank mounting bolts. Since they're black and my bike is black too, they're pretty much invisible between the tank and the lower fairings.
I kept the cowbell for decoration and also to hide the wires connected to the horn switch. The 2 horns are powered by a plug and play relay harness from Eastern Beaver.
I'm happy with my install and these horns are pretty loud. Close to the Stebel Nautilus as far as db. Trust me, I get noticed when I use them.
Check Eastern Beaver if you need a plug and play dual horn relay harness. Top quality and fast shipping. They're made in Japan by a Canadian guy living there.
http://www.easternbeaver.com/Main/Pr...horn_kits.html
I'm no electrician either- if I work at it real hard I can sometimes put batteries in the TV remote correctly, lol...
HD Air Horn vs Mini Beast
On my 05 Ultra, I installed the HD Air Horn when it first came out and like some of you at first I was happy with the sound. I was not impressed with it being plastic. After about a year it didn't work so well - meaning the sound wasn't nearly as loud. Perhaps it got wet inside... Just not sure. I finally decided to purchase the Mini Beast after reading nothing but good things about them here. I picked up one new from Ebay for 149.00. It looks just like the air filter cover on the 05 Ultra, it's the same size, heavy solid chrome and is plug and play and it is LOUD!!!. Much louder than my "broken/quiet" HD and I'll bet louder than the HD when it was new. I can't imagine anyone not being happy with the sound, finish of these horns.
Joe
Joe
Mini Beast II
Not the cheapest but, it is loud (128 decibles), good looking (lots of styles and finishes) and has a great reputation for working.
http://www.thepropad.com/products?pa..._id=8&vmcchk=1
