Stripped torx head on derby cover
I think with a drill there's at least a small chance the bit will slip and mung-up the derby cover. With the chisel idea there is little chance of this happening. As someone mentioned, a punch should work fine in lieu of a chisel.
If the torx is stripped you already have a nice big pilot hole to guide your drill bit. It's not going to just jump out.
You get to use both hands on one tool to safely guide the drill home. Takes a second to drill the top off the screw.
With an impact driver you're using two tools and one of them is a Hammer! And you're swinging it directly at your aluminum primary while holding another tool.
With a chisel and hammer....same thing kinda. A chisel or punch will take a nice chunk out of the chrome of your primary if you happen to miss.
The only time I ever use a punch and hammer is when you cannot get to the front of the screw (like close quarters)...otherwise the drill everytime...
No offense to anyone the prefers the other methods. Guess I'm just good with a Drill or shoot maybe I'm just afraid of hammers?
lp
lp
