Few Pics and projects done today~shock~Battery~Flash2Pass
Did a little of this and that today...I took TexasBowhunters advice on the rear shock oil change, I put Amzoil 10wt. I took it for a ride I am pleased w/ the results. I used a make~shift press to drain and put fluid back in. Thought maybe you may be interested how some folk work around their bike
I put a new Deka Battery in paid $79 at a Battery Warehouse bike turns over a little quicker
Installed a Flash2Pass garage door opener $62...while I was in there I saw the left Fairing Bracket was Broke
Went around and tightened most bolt that were visible
I plan on changing the Fork oil before buttoning the "Old Steed"
In the Home you either take your original wall mount push button opener and replace with the opener they supply (easiest way, 5 min. job), with just 2 wires to hookup and mount over the old spot, or in my case I am mounting it close to the garage door itself and leaving the entrance/passage door into the home in tact (being mine has a lock button) so that I can reach around to the inside frame from the outside and push the button to close manually without walking threw the garage to close. I was surprised how easy...it is so easy even a Caveman can do it. I am not a Caveman per-say but I am pretty close once home (mancave).
Some good tips on the bike, but I also enjoyed the 'shop' pics. My guess is about 24x36 or perhaps even 30x40 or so with 2nd floor storage. However, for PA I think I would have insulated it a bit! However, there does appear to be some standing timber for wood heat seen through the window....
