Transmission Fluid Change
Old 05-20-2010, 10:35 PM
StanfordMan's Avatar
StanfordMan
StanfordMan is offline
Does it matter if the fluid in the transmission that I'm replacing with Redline is synthetic or conventional oil? Do I need to do anything other than simply drain the old fluid out before I add the Redline? i.e., Do I need to use something to flush out the old fluid before adding the Redline?
Old 05-20-2010, 11:50 PM
dawg's Avatar
dawg
dawg is offline
Received 2,965 Likes on 1,715 Posts
Nope, drain and change.
Old 05-21-2010, 01:20 AM
CroK's Avatar
CroK
CroK is offline
and it only holds 24 ounces, not a full quart. You may even find that a small amount gets dumped out the vent, even with just 24oz. If that happens, it's ok, just make sure it isn't a leak. I run mine about half way between the two lines on the dipstick, so it won't get pushed out the vent.
Old 05-21-2010, 02:38 AM
ripper43's Avatar
ripper43
ripper43 is offline
Not on 08, 09 and 2010 models 32oz is what both books call for. never had any puke out after a change that I know about.
Old 05-21-2010, 03:00 AM
1990 Heritage's Avatar
1990 Heritage
1990 Heritage is offline
Default Where's my writeing
Originally Posted by Sgt. Fury
My problem is my 90 EVO did not come from the factory with the writing on it, or the elements have washed it away.
Does any one know how to pull the drain plug on my trans?
Old 05-21-2010, 10:28 AM
CroK's Avatar
CroK
CroK is offline
Duly noted. Thanks for the correction!
Old 05-21-2010, 11:08 AM
07RoadHawg's Avatar
07RoadHawg
07RoadHawg is offline
Don't forget us lowly '07 owners....
Old 05-21-2010, 02:10 PM
Sgt. Fury's Avatar
Sgt. Fury
Sgt. Fury is offline
Thought the evos only had the trans plug there, the oil bag is under the side cover.
Old 05-21-2010, 02:26 PM
tedcmiller (Cry Baby)'s Avatar
tedcmiller (Cry Baby) is offline
Six-speed transmissions require more transmission oil than the older five-speed transmissions. The drain plugs for the engine oil, the transmission, and the primary are all the same. They can be removed/installed with 5/8 inch socket or a 1/4 inch hex wrench. If the O-ring is pristeen, use it again. Otherwise, replace it.
Old 05-21-2010, 03:40 PM
iclick's Avatar
iclick
iclick is offline
Yeah! We feel like redheaded stepchildren anyway with our small gas tanks, old frames, etc.--and now this indignity of being left off the 6-speed list!
Quick Reply: Transmission Fluid Change
