Pipes for the 2010 Street Glide
First of all, welcome to the forums. I like the D&D as well. All 3 of us at the shop run the D&D fatcat. that being said, V&H power duals are nice, Rinehart true duals are nice as well if you are looking for duals. Whatever you decide, hit us up for discounted forum pricing via PM or email or by calling the shop.
Drew
Drew
So you can fit a D&D fat cat 2-1(eliminating the stock pipes w/cat) with a free flow intake filter with no tuner /fueler!!
thought stock ecm would run it real lean as not able compensate
I'm not noticing things being any cooler.
It's not a tough job. If you don't have a 5/32 Tamper-proof hex bit for the one allen head bolt which is "tamper-proof" (which I did not), just take a small drift punch or straight slot screwdriver and a hammer, lightly tap the pin in the center of the tamper-proof allen from side to side a few times, it will break off and you can then remove the bolt with a standard 5/32 allen bit or allen wrench. You can take everything (diffuser discs, closed end cap, and the outer trim ring) off and leave it off. Or I chose to just remove the closed end cap and re-install the diffuser discs and the trim ring. I think it looks better this way.
I wish that picture was a sticky.... lol It's pretty damn obvious when you look at that you are not going to get the sound you are after with that hunk of metal in there.
I just got off the phone with D&D acording to them they say no tuner required on 09-10 bikes with thier pipe and a free flowing air cleaner. He did also say It will run cooler and gain 1-2% power with a tuner but stressed it wasnt needed. Just passing the info on.
It will run much cooler with a tuner and a proper tune from Dyno. That is a fact. If you want to throw on pipe and air without a tuner ahve it, my opinion varies from that of D&D's and were it my ride I would put a tuner. I don't care how it is setup, a tuner is well worth it any day of the week.
Drew
Drew
