I can't take the squeaking anymore
Get cha some silicone and spray it on the rubber muffler hanger on the rear of the bike. If that cures it, it will only be temporary. I ended up taking the saddle bag support off and put it in a vise and crushed the steel that holds the rubber thing a little bit. If it in fact is the hanger, try my suggestion. Slightly crush it on the top and bottom AND on the sides. Not too much though! You want it to be tighter, but still allow the flat steel piece to still slide some as it needs to be able to move to absorb movement of the pipe. Might want to take that chrome cover off and see it that is the culprit...
It's your floor board. The front floorboard mount (on both sides) has a 1'8" of clearance between it and the bracket mount. I used a nylon washer wedged between them and held it in place by the mounting bolt. Does that make sense??? Anyway - look at the front attachment and you'll see what I'm talking about. Do both sides - because the other one will do the same thing eventually.
1 Post
Mine was squeaking like crazy too. And it came from the same spot as you described. I narrowed it down to the upper front motor mount. The one with heim joints. Took it off, cleaned it and lubed it and the squeaking went away. Just to see if thats your problem, just spray some lube on the joints and work them by hand a little, is the squeak stops, remove, clean, lube and replace.
same thing happened to me at 1,000 miles pulled and blue locktite them all all of them were loose
