What kind of GPS?
Garmin 765 with stock mount stuck to the tach face--can still see tach needle sweep 2500-4500rpm (not that I need to see it anyway).
The unit has a MP3 player from a SD card or can use the line out into HK aux in.
Did a 250 miles last Saturday in intermittent rain and just put a zip lock baggie over the whole thing-- not a problem.
The biggest problem with the Garmin's that I have had relates to the power cord slot. I always removed the unit from the Ram mount when I parked the bike, and to do that, you have to disconnect the hardwired power cord from the unit. If you use internal battery power instead of hardwiring the unit, it will only last for an hour or so. The metal wings holding the power cord slot in the side of the unit will eventually dislodge and make it inoperable. I have had 2 garmins that did that, and could not be repaired. Every time you pinch the release tabs of the power cord to remove it, the housing gets some stress applied to it and will eventually fail. At least in my experience. That's why I got the Zumo, which has a completely different and much better power slot which has not given me any problems in 2 year of service.
I just slot the 765 into the cradle and for removal press a button and the 765 comes off the cradle.
