Installed w/ Pictures--Tour-Pak Turn Signal Conversion Kit
A couple of quick points; sort of the Cliff Notes version:
Tools required: a 3/8" socket or wrench to remove the nuts securing the pouch inside the tour pak.
Materials required: Electrician's tape to wrap the electrical connectors removed from the bulb housings.
Tips: To snap open the bulb housings, use your fingers to spread the recesses in the light gray half of the bulb housing at the two points where the darker gray tangs rest.
The bulbs have offset (one high/one low) tangs so the bulb has to be oriented correctly to reinstall into the bulb socket--the recesses in the socket are easy to see to orient the bulb correctly; just push and twist.
When assembling the wires into the six-wire connector at end of the "auxiliary harness" that connects to the Y-harness, pull back the black conduit from the wire ends to create more free play/spread for the individual wires so it's easier to position them for insertion into the connector.
For others who have done this installation, please add any tips you have, or, as an earlier poster mentioned, if you've added features to the tour pak lighting, provide p/n's, pictures, etc.
Carl
Carl
I plugged the HD module that converts the turn signals into a run/brake function into the tour pak harness and get a loud buzzing noise when I apply the turn signals. Sound is coming from the tour pak lights or the relay that's mounted under the lights.
Harleypingman - did you get the same result / buzzing sound?
I just checked the bike and no buzzing sound; didn't hear any buzzing sound Saturday when I did the installation. The only sound is the relay in the auxiliary harness under the right side housing clicking; similar to the brake light relay if you pump the lever--had the same relay/click Saturday.
As mentioned in my OP, the run/brake/turn signal module for the turn signals is connected downstream to the Y-harness from the tour pak turn signal conversion kit. I'm not using any kind of load equalizer and the BAL-1R tail light works perfectly. So nothing was disturbed by adding the tour pak turn signal conversion kit.
Don't know why you'd have a buzzing sound.
Carl
PS: For the DIY'er, the run/brake/turn signal module for the turn signals could be used to provide the same function (better actually since the Emergency flasher function would be retained) as the tour pak conversion kit by simply splicing the left and right turn signal wires from the module (IIRC a brown wire and a violet wire) and supplying those circuits to the tour pak bulb housings. I did this with the HD saddlebag spoiler LED's to have them function as run/brake/turn signals--worked like a charm for 2+ years until I sold the bags as part of my repaint project.
My tourpak lights are already running lights and brake lights stock from the factory...................so this kit would make them directionals as well?
For $55, I think I'll pass.
My side LED marker lights on the tourpak are wired in with the directionals, so they flash with my directionals.
Steve
Steve
If you have the run/brake/turn signal module, you could do the same thing with the tail lights in the tour pak and create turn/brake/turn signals there; at least that's what I did with HD's saddlebag spoiler LED's.
Carl
