You think thats bad wait till you change your fork oil.. Now that's dirty and stinks even after only 5000 miles. Check out iclick's method for changing it makes the job easy.
I just did mine again after only 1,700 miles because I'm going with the SE fork oil. It was just as black as it was at the 40,000 mile change.
And boy, does it ever stink!!!!!!!! As I was draining the oil, the wife was watching and she left! She couldn't handle the smell! Hey, maybe I could put that stuff in a spray bottle on a timer and have it going off in the garage!
Atrain did you change out your clutch spring when you did your 107?
I did not change the clutch spring and so far no issues. I plan to do the SE compensator sometime this season, still I am undecided whether to mess with the spring while I am in there. If I get any slippage over the next month then I will change the spring out. If not, I will probably leave it alone.
