Lope of a Woods 555 cam
Old 02-01-2011, 08:28 PM
18BKLR's Avatar
18BKLR
18BKLR is offline
Originally Posted by RK_RIDER
low idle can and will effect battery charging. I have also seen where it contirbutes to ultra short life on the stator as it tries to work harder and if there is a week spot in the windings it will fry. Had a bro go through three stators until we figured out he was setting his idle way down about 800 or so, I'ts been 2 years on the same stator rpms set at 1000-1050.
The research I have done tells me that the charging system is only really charging around 3000 rpm's. From there down you are not producing much over 12 volts. I set my Tmax up a little at a time. I had that noise on quick blips on my bike as well until my Tmax learned the new fuel curves and timing curves. It started with a very sharp angle on the graph that I slowly smoothed out. Once that was done I would bump it down a little more and more till I got around 850. I have not noticed any ill effects on the chargind system at all. I also don't let it sit and idle and not charge. Just my experience and I suppose everyone's is different.
Old 02-01-2011, 08:51 PM
RK_RIDER's Avatar
RK_RIDER
RK_RIDER is offline
You are correct in the fact that in a perfect system the charging system is not putting out enough to really charge until higher rpms. As you stated it works okay for you but another bike/system with more electric use or system that varies slightly from the norm, say a not in top shape battery can have problems with low rpm idle stressing the components in the system.
Biggzed's Avatar
Biggzed
Biggzed is offline
Nothing sounds nastier than a set of SE211 cams with 10:1 compression.
I can't believe all the people that lower their idle just for the sound, BWTFDIK.
Zach
Old 02-02-2011, 06:00 AM
N-gin's Avatar
N-gin
N-gin is offline
Zach
People change their exhaust just for the sound. LOL
Old 04-13-2011, 08:27 PM
N-gin's Avatar
N-gin
N-gin is offline
555 installed 198 CCP, 103cuin., Crank balanced, stock heads, Wrong tune for engine. Im working on tunning it.
http://www.youtube.com/watch?v=dThUiiFu6sk
Old 04-13-2011, 11:08 PM
scot210's Avatar
scot210
scot210 is offline
Thank shovel is music to my ears.
Old 04-13-2011, 11:11 PM
Northside's Avatar
Northside
Northside is offline
I guess I missed the whole point with my motor build and cams. I never cared about how my bike sounds at idle. They sound great between 5000 and 6000 rpms though.
Old 05-03-2011, 05:16 PM
dbr1990's Avatar
dbr1990
dbr1990 is offline
Lope is over rated. You can lower your idle to get that if you want on a stock engine. Chop is what sounds good. My 10.7:1 107" w/ Mackie 598s running at 1088 rpm.....now that is Choppy.
Old 05-03-2011, 06:44 PM
N-gin's Avatar
N-gin
N-gin is offline
Wellll !
Lets see you post a video
Old 05-04-2011, 05:03 PM
dbr1990's Avatar
dbr1990
dbr1990 is offline
Couldnt get my flip to work.....I will try again tonight
Quick Reply: Lope of a Woods 555 cam
