I liked the idea of removing the passenger floorboards,then remove the passenger seat.....then sit her **** out on the sidewalk......screw the empty holes!
Sounds like that is all you will have to screw anyway :-)
Why wouldn't that work? Simple enough solution. If you have a need to make it more difficult, hardware stores carry plastic and rubber plugs in all sizes. Just take one of your bolts in for sizing.
The only problem with this idea, after she talks with her friends and get's a good Lawyer, they'll be sitting your chit out on the street and all you'll have to screw is empty
holes. plus your pocket's will be empty!!
Yeah you're SO right....now mind you,it was only a suggestion,the lad here wanted suggestions,never once did I say I was gonna do it!
Since I only ride solo, I removed the passenger footboards and brackets. But, now the four mounting holes are exposed. Any ideas on covering them? I'm not a machinist or metalworker, so I can't fabricate anything. Any existing covers available? Maybe painted bolts reinserted?
