Draggin Baggers install on RoadGlide with cruise
RE: Draggin Baggers install on RoadGlide with cruise
Roady - Does the hassle of removing the tray go away if the rear tire is out of the way? Seems like it should, but don't have the bike yet, so I wanted to ask. Just ordered the system for my '07 RG that will be here in May'ish. I will be swapping out the wheels and planned on installing the draggin bagger system at that time.
Yours looks great. Congrats.
Bigzzed...karl & i had to pull the axle and roll the rear tire back just to get to it...i made a tool which worked great...but Shearpin got the tray out...glad he was there...that one bolt is a *****, i figured it was NOT gonna go back in so we pulled the wheel....made it lots easier
Thanks Bryan - I figured that would make it easier to get to. I plan on swapping the wheels and exhaust at the same time the Draggin Baggers system goes on, so I will have plenty of room to work. Did you figure out a switch that will work on the dash. I think that sounds like a good idea.
ORIGINAL: Bryan TTM
Hey Bryan you cheated!!!!! That bolt and the battery tray is most defintly the hardest part of the whole job. Removing the wheel would certainly make things easier to get the bolt out but you still got to wrestle the dang on battery tray out of there. I think it is almost like one of those brain teaser, trick puzzles.
ORIGINAL: Bryan TTM
workin on it...got one i can dremil into the lower dash...lookin for the supplier to HD on the factory switches...need a momentary rocker with no writin or light
BZ
