Changing Ultra fork oil the "easier" way?
In my case, changing in the 1K to minimize the dive of the front end when braking... using the SE Heavy. Less expensive to try first before changing for progressive inserts.
If the service interval is 50k, which requires disassembly and inspection, why not do the simple oil change every 12k as was the service interval with older bikes? (10k is easier to remember.) Can it hurt? Then if you want to disassemble at 50k go ahead, but I'll probably wait, as when I disassembled one of the forks on my old RK at 100k for a leaky seal everything looked good, including the bushing.
Thanks for the how to..........
Do a fork oil change after 20k and you'll see why. The oil looks like you took a lb. of metal paste and mixed it into the oil--dark, very dirty, and smells awful. Do it again in another 20k and it's just as bad, or at least mine was. I will change every 10k from now on.
I did this a few weeks ago and ended up using what's called an adjustable box wrench to remove the fittings at the top of the forks. Do a search on the internet and you'll see them. I used an impact driver to remove the drain screws.
I had the wrench in my tool box and it worked well for me.
I took the ignition switch out in the "off" position so I could move the forks. I also removed the spacers and nuts underneath it to remove the plastic panel under the switch in order to remove the bigger panel that includes the rocker switches in order to get to the top of the forks.
Secret....you can remove the ignition switch from the "Accessory" position using the same technique as you do in the "Fork Lock" position.
This will allow your front end to be unlocked and you will not need the tool as he used in the video. The only thing that you do have to do is disconnect the battery or pull the maxi-fuse in that the bikes ignition will remain in the accessory position and some things will still be electrically hot until you do disconnect the battery or pull the maxi fuse.
I just did this to a 2011 and it should work for bikes at least back to 2007.
I made the device you are referring to a couple of years ago to service my 2009 and buddies bikes. It is basically a 12" piece of plain copper tubing that is configured to hook up to a Mity Mite vacumn device. You pull the screws out of the bottom of your fork tubes and hook up the tubing device and simply pull about 20 or so inches of vacumn to empty the tubes of old oil. To refill with new stuff you pull another vacumn with the new oil in the reservoir and when you reach 20 inches or so of vacumn you release the valve and it is sucked back into the fork tubes. Elapsed time is 20-30 minutes, start to finish and you remove no tins, switchs, etc. It is slick, Top.
