Need Help,,09 Ultra Bumpers
I didn't need to remove the wheel.If I recall correctly there was a nut that had to be removed on the inside of the fender under the fender tip light,and the 2 nuts(1 on each fork).These can be a little difficult to remove because you have to bend a locking tab away from the nut.Luckily I had a socket(I forget the size)that gripped the exposed top of the nut and I could rotate the nut, and the locking tabs backed off.When you put the nuts back on,remember to pinch the locking tabs against the nuts.I found a small set of needle nose vise grips works well for this.
