What did you do to your bagger today?
3rd time is a charm? Have a 2002 EFI Road King that was parked over 8 months. Changed oil, oil filter, tranny fluid, flushed and replaced gas, replaced leaky fuel line, and bought a new battery. Engine turns over but does not start. Replaced plugs and still does not start. Added Techron fuel injector cleaner and still no go. Done all I know what to do. Thinking about calling a mobile mechanic unless there is something you see that I have missed.
Busy afternoon in Okinawa:
Bled and refilled all three holes, finished upgrading my my crankcase breather and pulled off the gutted headpipe and installed a set of Cobra Powerports and Big Louie 4" Mufflers with 2.5" baffles, then loaded my new tune....
Then a few beers
Then a few beers
Thanks VRADMAN. I'm going with Trask for the turbo. Revolution trued the crank along with balancing and welding. S&S did the case bore and timkin. It's got 117 s&s jugs with CP Pistons and rods. 259e cams sitting in a fueling high flow pump. Heads are ported and polished. I'm not so sure about the cam but it should make decent power for now this way.
You'll notice a difference in performance with the stock filter. Suggest K&N again and any cover that allows some forced airflow. I use the bobber with the opening pointed forward. Simple, subtle and works well.
Nothin' fancy.
OK...so do tell. Must be running well if you're up to all this. How was the ride? How's she runnin?
I imagine most have moved on to newer scooter's with EFI and all, but my 98 RK is in need of an updated air filter.
I am completely stock with original Keihin carb. It does have a KN filter, but the plate is warped and I want to update.
I have been looking at the big suckers, but would appreciate some input.
I will probably just go back to the OEM filter for now.
Thanks all
Thanks all
Nothin' fancy.
well over the last 3 days I replace bushings in rear swing arm, replaced front motor mount, changed clutch cable to +6 for the wo 575 bars, red leds on the gages, inspected cam tensioner shoes, took baffles out of cobra pipes, added chrome bezels to the gages. then went for a short ride
