What did you do to your bagger today?
  #13111
Old 02-08-2019, 06:21 AM
MyFavRk's Avatar
MyFavRk
MyFavRk is offline
Received 6,478 Likes on 3,901 Posts
Finally got the front end of the bike polished , along with the rims . Getting new tires put on this week .
Rick80 (12-11-2019)
  #13112
Old 02-08-2019, 08:24 AM
MikeEyre74's Avatar
MikeEyre74
MikeEyre74 is offline
Got the defective right hand side "Cruise Set/Resume" switch swapped out with a replacement and did a clutch adjustment. While doing the clutch adjustment, found that turning the jam nut loose and then trying to twist the cable to the "short" position was a PITA.. It just wasn't spinning closed unless I grabbed it with pliers and twisted it around at the bar end to get that cable shortened.. thinking I need to replace that cable?
  #13113
Old 02-09-2019, 01:13 AM
rubberguy's Avatar
rubberguy
rubberguy is offline
lube your cable, and squirt some lube on the threads and let it work its way into the adjuster
  #13114
Old 02-09-2019, 11:55 PM
Nightsterroadtripper's Avatar
Nightsterroadtripper is offline
Added new led headlight, windshield trim light, turn signal led light. Upgraded my speakers with Rokker system. Can’t wait to ride this summer.
  #13115
Old 02-10-2019, 03:06 AM
Bafflingbs's Avatar
Bafflingbs
Bafflingbs is offline
New crash bars...
  #13116
Old 02-10-2019, 07:42 AM
rob1690's Avatar
rob1690
rob1690 is offline
Deleted
  #13117
Old 02-10-2019, 07:48 AM
rob1690's Avatar
rob1690
rob1690 is offline
rode 2 days during "Spring of deception".
  #13118
Old 02-10-2019, 07:54 AM
rob1690's Avatar
rob1690
rob1690 is offline
How did you clean your wheels?
  #13119
Old 02-10-2019, 08:10 AM
MyFavRk's Avatar
MyFavRk
MyFavRk is offline
I actually bought these rims used this fall and decided to polish them along with the rest of the front end . It was a very long process that I wouldn't want to do again . I made a jig with a pieces of plywood and a 1" piece of pipe so the rim would spin as I worked on it ... Started with 800 grit sandpaper and worked up to 2000 gritt . Once the rim was totally smooth , I hit it with a red rouge using my drill and a buffing wheel and finished it off with a green jewelers rouge . They turned out really nice , but to keep the shine I will be polishing them every once in while with Mothers Chrome Cleaner , I believe in that stuff , works awesome .
If you just want to clean up your rims I would just use the Mothers and give them a really good cleaning . Use one rag to apply the Mothers and another to wipe them clean . I use a scissor jack to raise the bike off the ground , so I can spin the wheel while I clean . I haven't found a product yet better than this , it cleans up dead bug , road tar and break dust . Makes them look new again .
rob1690 (03-09-2019)
  #13120
Old 02-10-2019, 04:11 PM
Zedbra's Avatar
Zedbra
Zedbra is offline
Pulled out my radio and packed it up to send back to Iron Cross. Regardless of what the manual says, this deck would only slide out the back after taking the rubber gasket off from around the front.
Quick Reply: What did you do to your bagger today?
