What did you do to your bagger today?
Mine is not one of the chinese ones on ebay. I did consider them, but went with the EZ-up version.
Getting it up on the stand is not too difficult. It is just like the video.....i put all my weight on the left leg, and it goes goes up on the stand.....it feel like a slow motion action when it is happening. Getting it off the stand...You just put it in first gear, and ride off. If need be, it can be pushed off the stand without too much trouble.
Got the Thunder Max installed, rc exhaust header and the new Continental tires. She hasn't responded this well ina very long time.
Took her out for a 30 mile juant.
finally got out for first ride of the spring around 75 miles felt good winter has been too long!! keep coming warm weather I am ready!!
Why do members respond with totally useless info like, “I patted it when I walked by it, it put gas in it and went for a ride”. FFS folks, submit useful post.
Jeesh
Jeesh
Not so rough, Francis. Not everyone works on their bike every day, like we used to decades ago, but, still want to be a part of the thread. Sometimes riding it is the best thing one can do. tp
Mallard Slayer (03-24-2019)
Legend shocks
Bought a pair of 12" Legend Revo shocks for my 2011 Road Glide Ultra and put them on a couple weeks ago. Figured I put them on my bike and if I didn't like them I would replace them with the stock shocks and put the Legends on my wife's 2010 Street Glide and see if she liked them. Yesterday was the first nice day to take the bikes out so we took a really rough road (which isn't hard to find in Wisconsin) and they performed AWESOME!! My wife took an ibuprofen when she got home because he road was that rough but my ride was completely 1000% better than the stock shocks. When we got home I called my Harley dealer and ordered a pair for my wife because mine are STAYING on the bike. We have about 80,000 miles on the bikes and really should have done this YEARS ago. Now I am thinking about having the Legend kits installed on the front of both bikes, too!!
Finally installed my screaming eagle Kevlar clutch and spring. Changed the oil with syn3, primary with redline, and trans with redline shockproof. All I can say is what’s difference. Clutch engagement is nice and crisp, clutch spring is not to stiff. Rides very tame when you want it to, but she runs really angry when you want it to. If you like to slam through the gears and go, all I can say is it will hook up. So far this seems to have solved my clutch issues. Old clutch didn’t look to bad. New one definitely has more meat to it. Got a nice 75 mile ride in while the weather finally turned nice.
Winter came to an abrupt stop last week and it kicked my motivation in high gear to complete my winter maintenance and mods. I tackled quite a few projects and I'm proud of all I managed to accomplish with some basic tools, a service manual, videos, forum threads, patience, and a little guidance here.there from a local Indie when I was having blonde moments (I had a few). Only specialty tools I needed was a 36mm wrench for the forks and a rear axle nut wrench.
List of maintenance/mods: complete tear down of front forks:
* replaced bushings, added Progressive HD springs, polished the lowers, and then had them Cerakoted
* swapped out my all fairing lights to blue LEDs, including pulling the speedo/tach apart and soldering new LEDs. I sent the stereo to Iron Cross to repair and modify. Ran USB input into glove box
* repaired cracked mounting holes on outer fairing with 3M epoxy
* pulled rear swing arm off and replaced the bearings. One was almost seized and cracked right across the middle. Replaced the rubber bushings as well
* pulled tank and replaced fuel filter
* replaced air intake, derby cover, and cam cover
* replaced shift linkage
* replaced air horn with bottle opener and Fiam blaster
* replaced air shocks with Pro Action shocks
* polished all chrome while pulled off bike and then what was left remaining on the bike
* added glovebox liners, Quadlock phone holder, new headlight bezel (just did this today)
* drilled out front turn signal bezels to accept dual amber/white 1157 bulbs
* repaired rear cush drive pulley as something jammed up in the belt and popped off one of the tack welds and bent the inner guard a bit
* installed Progressive Touring link but I need an alignment to get the link to properly install
All that is left is to get proper pipe clamps to fit the Reinhart system (the old ones snapped off when I pulled off the rear slips) and I am going to get my Indie shop to adjust the alignment and install my new motor mount. I pulled the rear tire and loosened the rear sing arm three different times to try to pop the alignment into place but I am still a few mm out and the rear tire is close to the fender on the right side - my Progressive Touring link will not install due to poor alignment. I figured I'll let the Indie install the new front motor mount I bought from him when he goes in there to loosen everything up for the alignment. It will be insured and riding season again in 2 weeks; I am 1.5 months ahead of my May deadline for completion. I was so stoked to get it together that I went for a quick rip around the neighbourhood without pipes, grinning the whole time.
Fairing mounted with new light bezel
Fuzzy glove boxes
Quadlock phone holder mounted, replaced the SiriusXM radio that always cut out due to poor signal (poor signal due to living in the mountains)
Back together and running, minus the pipes that are waiting for proper clamps
Fuzzy glove boxes
