HD Noob question... Throttle Roll-off Position?
I'm the ecstatic owner of a brand new 2011 FLHTC, upgrading from a VTX 1300S. I've had her for 3 days, racked up almost 300 wondrous miles, but have a question about the throttle... My Honda didn't do this, so, I'm not sure what the purpose is...
When the throttle handle is positioned at idle (engine on or off) I can roll the throttle past idle and further 'closed' (?) than where the spring takes the throttle handle back to idle... this doesn't seem to change anything when the engine is idling, cadence, note, idle speed all stay the same...
I can find only *1* mention of "throttle roll-off position" in the owners guide, and that's when one is trying to change the EITMS setting... I have not changed this setting, and whatever the dealer or HD set is the way EITMS is at this time.
Otherwise, I can find nothing about what this is... any ideas? The salesperson at my HD Dealer says it's to control the EITMS myself while riding, but again, there's nothing in the manual about that...
Thanks... any comments are appreciated...
Holt
Holt
EITMS is the engine heat management system. If you roll it forward and hold it there for approx 5 seconds you will see the cruise control light turn either amber or green.
Amber- heat management off
Green- heat management on, when your engine reaches a certain temp while stationary the rear cylinder will stop firing so less heat is felt on your leg. I always keep mine in green position and it works good.
When you change the setting with the ignition on/engine off that becomes the baseline setting and it will remain that way until you change it again.
From the factory the baseline setting is OFF.
garymtx (06-09-2021)
Here's some info that I found awhile back, can't remember where I found it but here it is...
* ENABLING/DISABLING EITMS: 1). Turn the ignition switch to the ON position and push engine OFF/RUN switch to the run position (do not start the bike). 2). Push the throttle to roll-off position and hold. 3). After “approximately” 3 seconds, the cruise indicator lamp will either flash green (EITMS enabled) or red (EITMS disabled). Flashing lamp indicates EITMS setting. A solid (non flashing) lamp indicates cruise control setting. 4). Repeat procedure to enable or disable EITMS. The EITMS setting remains in effect until changed and does not need to be re-done with each start-up.
* Also. the EITMS should automatically activate whenever the bike comes to a complete stop and is idling during elevated temp. This should happen even if you don’t set as described above.
Good info from "2black1s" If you just want the temporary setting then go with this.
