Roadking mufflers backin out
Old 06-19-2011, 11:58 AM
sportyslr's Avatar
sportyslr
sportyslr is offline
Default Roadking mufflers backin out
For some time now my right muffler keeps backing off of the pipe. The clamp isnt loosening up. it ends up backing all te way off untill its almost 1/2 in left of pipe and all the way backed up on the haner. I am getting the fullsac conversion soon. Is te problem on the muffler side or the pipe side. anyting i do to prevent this from happenin every 400 miles or so, it is getting kind of annoying.
Old 06-19-2011, 12:20 PM
drukanfu's Avatar
drukanfu
drukanfu is offline
Spot torque it.
Old 06-19-2011, 12:21 PM
gregmay's Avatar
gregmay
gregmay is offline
You need a new clamp
Old 06-19-2011, 12:23 PM
Sharknose's Avatar
Sharknose
Sharknose is offline
You could try cutting an extra slot or two in the neck of your slipon. This would allow it to draw tighter against your pipe.
Old 06-19-2011, 12:25 PM
sportyslr's Avatar
sportyslr
Spot torque? I have tried new clamps and that didnt work either.
Old 06-19-2011, 12:26 PM
El Rey's Avatar
El Rey
El Rey is offline
Go with true duals, never have that problem again.
Old 06-19-2011, 12:27 PM
drukanfu's Avatar
drukanfu
drukanfu is offline
Put a big wrench on it and pull till ya see spots in your eyes.
Old 06-19-2011, 01:18 PM
Guntoter's Avatar
Guntoter
Guntoter is offline
Did you use Harley clamps? Anything else is less than adequate. No matter what clamp you use, they generally are one time use clamps only, meaning after they are torqued up, if you have to loosen you may as well replace. At the muffler at least. Those mufflers put a lot of pull on the connection when running hard.
Old 06-19-2011, 02:14 PM
sportyslr's Avatar
sportyslr
I did have the clamps that came with my vance and hines ovals and they were backin out so i put on the oriinal clamp. i will replace the clamp when i put on the fullsac conversion next weekend
Old 06-19-2011, 06:15 PM
Pastor John's Avatar
Pastor John
Pastor John is offline
I think it's a sign from the bike that it wants some aftermarket mufflers! Nothing that a little credit card action can't fix!
Quick Reply: Roadking mufflers backin out
