Need to rethink stereo upgrades
I may give this a try, then if the speakers aren't up to the task I'll look into something else, like maybe the J&M's.
You guys are giving me some good advice! Just what I needed.
That would be very convenient! The Hogtunes speakers are rated lower (50W) than the Elf amp (75W), although I doubt if I'd ever have it pumped-up that much to harm the speakers. I'm not sure what the rating is on the Tweeter Pods.
So which speakers are in the fairing? Anyway, that's another vote for the J&M.
Running the 7.25's in the fairing
I need to look at this one.
Yes I agree I want to look into it more when someone has used it.
What are Hearing Halters? I'd be interested in ear plugs that would filter out the road and exhaust noise, yet allow music frequencies through. I think that may be impossible since music uses the entire audio spectrum.
That's your ticket right there, so order the amp, I think the 135 is a deal also, I looked up the seller and may purchase one myself. Although I have just installed the Hogtunes, and have the Bazooka brand new in the box still sitting here, ah heck one more won't hurt anything.
What's your gut feeling between the two? I had a feeling running 1.5Ω wouldn't be a problem, as with the Tweeter Pods the head unit would be running that impedance. I don't think HT would configure them this way if they destroyed the head units.
I am using the ear Pro 3's and love em you can get on amazon pretty cheap. http://www.surefire.com/EarProProducts
The one thing about the Vibe is, I did have to do some modification to install it.
I had to use a hammer and chisel on my Tach and Speedo housing to make it fit.
Seriously, I did have to trim them back a bit with a Dremel.
So maybe the Elf would be better, as I believe it will fit with no mods.
I haven't heard an Elf, but the Vibe I have is set up so I can hear it clearly at 70 mph, showing 4 bars on the HK, this is with ear plugs and a FF.
Bob
Bob
The Elf E2125X I am looking at on Ebay is a 2-channel amp. That's okay as long as I can get the impedance matched up right. Isn't the 125.2 made by Arc? I think it's the same amp, but the Elf is considerably cheaper.
you can take a quick look at post # 90
https://www.hdforums.com/forum/touri...cs-here-3.html
My follow up on the Jm speakers I am not sure I would buy again. I would take a listen to the Rokkers but I am not going to spend the money to hear them. I can wait until I run into some to hear.
