Fluid Change Tools
Ok I seen a few posts on fluid changing but never really nailed down all the tools and equipment needed. I want to do this myself to save a few bucks. I have done a ton of fluid changes on my cars but the bikes are a little more delicate.....Can I get a list of recommended tools and equipment to do all the fluid changes please.....
you didnt say what bike, so lets assume its an 07 or later. you can do it with the tool kit in the bike. The three drain plugs all take an allen key that is part of the kit. dont forget the primary drain on an 07 or later is on the left side , under the primary acces cover. the primary access cover takes a torx bit that is also in the tool kit. if you have a nut on your oil filter, a socket for that. if you do not have a nut, you will need a small oil filter wrench. becareful and do not wack the crank position sensor.
For just a fluid change you just need a 3/8 allen, 1/4 allen, a 27 torx, and wrench for the oil filter.
This on newer bikes nit sure how far back. |
Sorry this is for a 2009 FLHP road king police....What about lifting the bike or keeping it level?
Originally Posted by CoastlineAmps
(Post 8481392)
Put a small block of wood under the jiffy stand when filling the primary. Oil level is suppose to be checked on the jiffy stand. When draining I will sit the bike upright and lean it to the right to help make sure more drains. |
You'll also need a drain pan (an old darkroom tray works great), something to collect and transport the drain oil, a wire brush (for cleaning the plug threads, a torque wrench and the proper bits (for drain plugs and primary cover fasteners. You don't need a lift.
Be advised there's a lot more to a scheduled service than just changing the fluids--see your owners manual. |
The most important tool for you is the factory service manual. It is worth every penny.
Originally Posted by bberck
(Post 8481384)
So with the bike on a normal left lean from the kickstand, will it drain properly? Or just sit on it until it drains.....One more thing. Do I have to do any tensioning adjustment on the transmission case?
(Post 8481479)
Take a look at the magnetic plugs and check for large chips or flakes which could mean a bearing race or other problem. fuzz is normal...it looks like grease but it's actually metal particles. |
© 2024 MH Sub I, LLC dba Internet Brands
