103 Compression numbers?
Old 07-01-2011, 04:39 AM
77Tulsa's Avatar
77Tulsa
77Tulsa is offline
Default 103 Compression numbers?
The HD maintenance manual publish the 103 compression ratio at 9.6-1. Does anyone know what the installation of the 0.30 cometics head gasket will increase this to?
Old 07-01-2011, 05:14 AM
kingkingking's Avatar
kingkingking
kingkingking is offline
Whats the stock head gasket thickness?
If you know that then it is easy to work out the change in volumes and the new comp ratio.
Old 07-01-2011, 05:18 AM
V2Evo96's Avatar
V2Evo96
V2Evo96 is offline
I'll take a stab a this since no one has come in. I THINK the OEM head gasket is 0.040 or 0.045. If it's 0.045 and you want to run a 0.030 gasket your effectively taking 15 thou off the head.
I THINK you would be around say 9.8-1 or 9.9-1 but it's very approximate. I hope someone comes in with the knowledge to assist more accurately.
Old 07-01-2011, 06:10 AM
77Tulsa's Avatar
77Tulsa
77Tulsa is offline
I found a calculator on big boyz web page that actually takes the cam info into consideration also. Static they said approximately 10.2ish correct with cams varies from 9.3 to 9.9. Don't really understand it all but the cam I am looking at is for 9.5 to 10.5 so I guess I will be good! Thinking about the HQ575H
thanks.
Old 07-01-2011, 06:39 AM
jmacdonald5's Avatar
jmacdonald5
jmacdonald5 is offline
..static refers to the engine being turned over, but not firing..compression is a little lower when you have the engine running...
Road Star
Engine Mechanical Topics
08-09-2017 05:48 AM
InthewindMN
13
02-20-2015 07:20 PM
FICS1
05-01-2014 04:22 AM
Dyna7
12-29-2013 01:03 PM
steve303sg
09-01-2013 02:18 AM
Quick Reply: 103 Compression numbers?
