Safe way to jump start battery
A car puts out just as many volts as the bike. They are both 12V systems that run around 14.4 when the engines are running. The car's alternator puts out more amps, but only when they are demanded by the load put on the system. The danger comes when jumping a 6V system from a 12V one.
Short story long, yes you can jump start your bike with a car that is running or not.
I found out the hard way there is only one real safety issue when charging, boosting or jump starting anything.
Sparks from a bad connection on the jumper or battery charger ends are mostly harmless when the battery is cold. When the battery acid heats up from a rapid charge, the gases that it produces are very explosive. If you have had a booster on a battery for any length of time and the conditions are just right, any little spark can explode the battery.
Dennis
Dennis
too many stories of folks loosing stators and regulators after jumping a bike battery. What you should do is take the battery off the bike, slow charge it, let it sit for 12 hrs, then test it for static state of charge. You can goolge to get the chart. The numbers are something like 12.4 volts is 50% charged, 12.7 is 80% charged, etc. Anything below 12.3 volts is a bad battery. If battery passes, then you need to test your charging system.
of course, if battery is 4 years old, don't expect much more from it. And yes, trying to keep a weak battery charged, could overload your battery.
I know that to be true with the old wet cell lead-acid batteries. Is it still an issue for the AGM style batteries? Just wondering, cuz I'll still probably take the same precautions.
you are correct on the volts , I meant amps , but you are wrong on the car can be running , THE CAR NEEDS TO BE OFF , JUMP OFF THE BATTERY ONLY ,if the car is running I have seen guys fry electrical parts on their bike , I have never seen anyone do it off a battery only jump , ask your service dept , the other day I saw a guy jump off a running car and as soon as it cranked up his electric compass was spinning , fried , there is no need to have the car running , the bike doesn't need that kind of amp out put
