Squeal/Chirp on Decel
I have a chirp or short squeal when I quickly close my throttle and the bike is in motion. I am thinking it may be in the primary because the noise is noticed at the beginning of the shifting of the momentum. Could a compensating sprocket do this? Other than that I would suspect a bearing.
I know that diagnosing noises is hard especially if you are not hearing it yourself. I tried the search function first but it is not working for me right now.
The bike is an 06 Ultra with 56k on the clock.
dougbk
I didn't think you were supposed to put anything on the drive belts. I never have on any of my bikes.
Yep, uh huh, that'd be it.
I know exactly what you're talking about. I had that same noise on my old Fatboy untill the service manager at the dealership gave me the fix. It's called "poly oil" made by Harley Davidson. It comes in a tube and is a clear grease. Just put a VERY SMALL amount rubbed on at 3 -4 locations of the rear drive belt. I did this once and 20,000 miles later still no chirps. And no ill effects on the belt. Cheap fix, give it a try.
I would raise hell with the dealer over that. No way they should change tires and not reset the correct belt tension.
